2001 ford lightning cant datalog
2001FORD
Post by 2001FORD »
2001 ford lightning u7158 having an issue getting the dataviewer to work. it will see it but stay at "acquiring vehicle information" tried first with 9r01 and then upgraded to 9r03 using dsdownloader and that was fine. when i tired to datalog again to got stuck at acquiring vehicle information. trued changing com port form 7 to 2 and nogo buadrate is at 115200 on tool and pc. should i try with other usb to serial ?? this is the same cable i did the upgrade with.
thanks for any help or direction provided
runtime.txt
528507643 Info: .\DataViewer.cpp, line 181, CDataViewerApp::InitInstance, DataViewer Version 3.3.0.8
528507643 Info: .\DataViewer.cpp, line 185, CDataViewerApp::InitInstance, The DataViewer is initializing.
528507909 Info: .\ParamTreeView.cpp, line 313, CParamTreeView::UpdateParamsFromLogData, Loading parameter tree from log file data.
528508361 Info: .\comm\httpconnect.cpp, line 208, CHTTPConnectThread::ExtractServerVersion, Server Version: 3308
528508361 Info: .\comm\httpconnect.cpp, line 194, CHTTPConnectThread::ExtractRunningVersion, Running Version: 3308
528508361 Info: .\comm\httpconnect.cpp, line 171, CHTTPConnectThread::Run, Exit HTTP Update Thread
528509609 Info: .\DataViewerDoc.cpp, line 761, CDataViewerDoc::OnUpdateToolInfo, u7158
529704733 Error: .\comm\SlipCommunicator.cpp, line 346, CSlipComm::ReceiveXml, PSLIP Receive Failed [Binary Package Size=0]
529704733 Error: .\comm\ToolCommand.cpp, line 338, CToolCommand::Execute, Transaction Retry: General error ocurred during data reception.
530004239 Warning: .\comm\ToolCommand.cpp, line 273, CToolCommand::Execute, Driver transmit failure
530004239 Error: .\comm\ToolCommand.cpp, line 338, CToolCommand::Execute, Transaction Retry: Error ocurred during data transmission to the tool.
530303121 Warning: .\comm\ToolCommand.cpp, line 273, CToolCommand::Execute, Driver transmit failure
530303121 Warning: .\comm\CommThread.cpp, line 359, CCommThread::ShutDown, Shutting down communications...
530600615 Warning: .\comm\ToolCommand.cpp, line 273, CToolCommand::Execute, Driver transmit failure
530600615 Error: .\comm\CommThread.cpp, line 574, CCommThread::ExitXmlRpcMode, ExitXmlRpcMode FAILED
530600615 Error: .\comm\CommThread.cpp, line 1088, CCommThread::GetVehicleInfo, GetVehicleInfo ERROR
530600615 Info: .\comm\CommThread.cpp, line 176, CCommThread::ExitThread, CommThread::ExitThread complete.
530600615 Info: .\DataViewer.cpp, line 311, CDataViewerApp::ExitInstance, CDataViewerApp::ExitInstance complete.
Return to “DataViewer/DV2”
