2003 mustang gt
revolution chip
burnt a tune onto the chip... installed the chip
did not read the chip. removed pcm from harness with no power
reinstalled pcm with revolution chip installed. pcm is stuck in program mode
any clues as to a simple way without reprograming with an ids?
revolution chip install takes out pcm programming?
RE: revolution chip install takes out pcm programming?
Is it OK when the chip is removed?
What makes you think it is stuck in program mode?
