2011 Ford Mustang V6 - Why are there 7 rev limiters?
Posted: Thu Sep 08, 2011 8:22 pm
I have a 2011 Mustang V6. It's a 6 speed manual. In the "modify parameters" menu there is the option to adjust the rev limiter for 7 different areas. Is one of them neutral and the others gears 1-6?
What I'm trying to do is see if there is a way to have it limit my revs at the light in 1st gear with the clutch in. MSD 2 step won't work for my car.
My Cobb Tuner on my STi had a really cool feature. I could set the above feature to say 4500 rpm's. So staging at the light, clutch in, stomp on the go pedal and it lays it up at 4500 rpm's until I dump the clutch. Then it had flat foot shifting points from there so it would only let the car rev to a set rpm's between shifts so it was all gas until the finish line. It would be awesome if you could somehow integrate this feature into the Trinity.
