TUNES FOR 06MonteSS
yotadog2000
TUNES FOR 06MonteSS
Post by yotadog2000 »
sorry my computer is shit it wont let me email them direct to you
ab12212156ctaorginal tune.grg
original tune
(290.65 KiB) Downloaded 130 times
AB12212156CTA_custom tune.grg
custom tune
(9.25 KiB) Downloaded 141 times
RE: TUNES FOR 06MonteSS
so what is it we're supposed to be doin?? you change/add stuff to your truck??
what's new/different since April 2011 when we did your last tune?
yotadog2000
long tube headers
4:10 gears
that last tune written does not match my last custom tune I gave you at all man... did you ever install that last JonMike_Yotadog_DiabLew_Tune_2.grg tune I had sent you??
because there is a LOT of stuff changed/different in your last tune written file above from how I had everything set correctly in the custom tune I sent you... tunes don't match at all...
yotadog2000
man i want to say i added more fuel at higher rpm i dont think i changed anything else tho
heh.. there's a LOT of stuff changed.. not just WOT fueling...
timing, tire size, axle ratio, inj. slope, and more...
yotadog2000
oh yea my bad i changed to new wider tires and had to change axle ratio to 4.10 cause of my gears i installed cause my speedo was way off
and the bunch of all the other stuff that's different - you made all those changes too??
so just go another -1% on your slope setting and you'll be good to go...
yotadog2000
Ok Sweet ill do that and thanks for working with me and my lame computer
hahaha np man...
yotadog2000
1 more question what rpm range do I need to adjust -1% or do I need too adjust all ranges -1%
you're not adjusting the WOT fuel... that adjustment I'm talking about is for your injector slope...
yotadog2000
Oh duh my bad thanks again
