Diablo Sport 80 hp chip
platinum
Post by platinum »
Just bought one of these (used)for my 01 F-250 7.3 installed correctly and the truck will run for 2 seconds and die. I have had the 40 hp chip installed for 3 years, and worked fine. Re-installed it and truck runs fine. Do you think the chip is bad, or do I need to do something different?? Thanks, Bob :?
Re: Diablo Sport 80 hp chip
platinum wrote:Just bought one of these (used)for my 01 F-250 7.3 installed correctly and the truck will run for 2 seconds and die. I have had the 40 hp chip installed for 3 years, and worked fine. Re-installed it and truck runs fine. Do you think the chip is bad, or do I need to do something different?? Thanks, Bob :?
The new chip needs to be reflashed to match your trucks calibration ID.
Use the 'Where to buy' tab above to find a dealer in your area that may be able to do this for you.
Mike
Return to “General Support”
