5.9 Cummins in Freightliner
Can you tell me if I can order a Predator U7130 to use in a 2003 Freightliner chassis with a Dodge 5.9 Cummins driveline? If not, do you have one that would work?
RE: 5.9 Cummins in Freightliner
no, a power puck would be better choice...
Thanks for the reply but I do not see a p/n for the 2003 Cummins...would the D7155 work?
Re: RE: 5.9 Cummins in Freightliner
Mike...I'm not seeing a listing for this year in the power pucks...can you tell me if the D7155 would work?mikel wrote:no, a power puck would be better choice...
RE: Re: RE: 5.9 Cummins in Freightliner
Yes. The puck is based on the engine, not the chassis, so one that plugs into a 03 Cummins will plug into any 03 Cummins, no matter what its in
Thanks...I did realize that however could not see a listing any newer than 2002 Cummins so wanted to be sure on the number before ordering.
