new predator user questions
njctd79
Post by njctd79 »
I just bought an 06 mustang GT. It came with a K&N CAI, BBK TB, underdrive pullies, BBK shorties, Flowmaster axle back and a Predator U7140 complete in the box.
I think the car has the provided Diablo performance tune in it but how can I tell.
I would like to experiment with small increases in the timing and shift firmness. Is this OK? Recommendations?
Would the car benefit from a custom tune now?
Thanks,
Kevin
ski
Post by ski »
To determine which tune is currently loaded in the car's ECU, Select 'Options'/'Last Tune Written' in the Predator's menus.
It's not recommended to change the timing values, unless the engine is experiencing pinging, or you want to use gas with a higher octane than the tune, e.g., 93 octane gas with a 91 octane tune(increase global timing by 2 deg).
If you're referring to a dyno tune when you say 'custom tune', then that's always a good idea, since every engine is different. But obviously it will cost $.
njctd79
Post by njctd79 »
Although a dyno tune is not out of the question I was referring to a tune emailed from a tuner like Bamachips built around the specs of the car.
ski
Post by ski »
Doug at Bamachips works with Predator tuners, so he can write a tune for your car.
njctd79
Post by njctd79 »
Is email the only way to talk to Doug. I dont see a phone number on their website.
bullitt1668
Post by bullitt1668 »
njctd79 wrote:Although a dyno tune is not out of the question I was referring to a tune emailed from a tuner like Bamachips built around the specs of the car.
How much some thing like this can cost?
All I have, engine performance, wise is 3.73 gears, off-road h-pipe, k&n cool air intake, and pulleys. And of course... the Predator (u7146).
2001 Kenny Brown Mustang Bullitt
ski
Post by ski »
njctd79 wrote:Is email the only way to talk to Doug.
Yes
ski
Post by ski »
I believe that Bamachips can do a tune for $75.
bullitt1668
thanks!
Too bad we don't have anything like that around here!!!
2001 Kenny Brown Mustang BULLITT # 1668
Engine:
DiabloSport Predator
Kenny Brown Suspension that also includes an Extreme Chassis Support System also by KB. 1 of 1 Made!!
njctd79
Post by njctd79 »
[quote="ski"]To determine which tune is currently loaded in the car's ECU, Select 'Options'/'Last Tune Written' in the Predator's menus.
After determining which tune I had I changed it to the 91 octane tune and the car went into limp mode. I think it may be the aftermarket throttle body.
Yeah, aftermarket throttle bodies often cause this issue.
Try removing it and replacing it with the stocker, all should be fine.
njctd79
Post by njctd79 »
I put the stock TB on, put the 91 octane tune in and now the car kicks ass.
What can I do to tune for 93 octane.
ski
Post by ski »
Advance the global timing by 2 deg.
njctd79
Post by njctd79 »
How about shift firmness. My booklet shows it can be changed but I dont see it on the Predator menu. I noticed I have version 28 and there is a newer version on this site. Would that change be on the new version. I have the U7140 for an 06 stang auto.
Return to “Predator Ford Gas”
