P0128 CEL. Can I have my map updated?
Posted: Wed Oct 05, 2011 4:23 pm
by grayforge
Hi folks,
I have the P0128 coolant temp too low CEL after setting fan temps and installing a 180 degree stat. Can you please update my tune to clear this CEL?
P/N: U7135
v.9r23
2006 Dodge Magnum SRT8
Thanks!
Posted: Wed Oct 05, 2011 4:31 pm
Here you go.
Posted: Wed Oct 05, 2011 6:43 pm
by grayforge
Thanks, I'll load it ASAP!
Posted: Fri Oct 07, 2011 12:49 pm
by grayforge
Spurious Post
Re: P0128 CEL. Can I have my map updated?
Posted: Thu May 30, 2013 6:36 pm
by grayforge
Hi Diablo Folks,
Could I please have another map updated to fix the P0128 CEL issue? I recently installed a Vortech Supercharger and it's included map does not have a fix for this issue, even though they include a lower temp thermostat in their supercharger kit.
Enclosed is my last tune written for this reflash.
Thanks!
Russ
Posted: Fri May 31, 2013 12:48 pm
grayforge wrote:Hi Diablo Folks,
Thanks!
Russ
here you go.
Posted: Sun Jun 02, 2013 8:00 pm
by grayforge
Perfect... that did the trick.
Thanks!
Russ
Posted: Thu Jul 10, 2014 12:45 pm
by grayforge
Well, I thought it did the trick, but it may have just slowed the appearance of the CEL. It still re-appears after I reset it.
Can you tweak the previous map you sent to make the low coolant temp CEL go away for good? Can you use the last map you sent or do you need me to send the current map back?
Thanks!
Russ
Posted: Thu Jul 10, 2014 12:53 pm
post a copy of the current last tune written please.
