mpg booster
Posted: Sun Oct 09, 2011 8:45 pm
by aviator14
OK Diablo, at the risk of posting a dumb question. I just want to make sure I understood the posts correctly. The new MPG tune is based on 87 octane gas correct? I am currently running the performance tune for better mpg, using the 93 octane and since I am retiring next summer, I would love to save a buck or two and the pump.
2009 Chevy 2500HD 6.0L V8
Airaids Cold Air Intake
Airaids Throttle Body Spacer
Gibson Swept Side exhaust
RE: mpg booster
Posted: Mon Oct 10, 2011 11:15 am
Yes, it is designed for a minimum of 91 octane.
RE: mpg booster
Posted: Mon Oct 10, 2011 4:53 pm
by aviator14
The MPG booster is designed for a minimum of 91 octane?? or the performance tune?
RE: mpg booster
Posted: Tue Oct 11, 2011 2:42 pm
by rjaro7
i went from the 87 octane tune to mpg booster and fuel economy along with performance are worse. and dont even bother trying to tow anything. i went from 10mpg to 6mpg towing the same rv to the same destination as i always did. back to 9r19 with 87 octane tune for me.
RE: mpg booster
Posted: Tue Oct 11, 2011 8:28 pm
by aviator14
OK, thank you. I think I may have to play with it a bit and see if the 87 tune or the performance (93) tune have a bid difference in mileage. I won't be pulling much anymore so I can probably go down. Did you use 87 with the mpg booster?
RE: mpg booster
Posted: Wed Oct 12, 2011 8:39 pm
by rjaro7
yes i used 87 oct. the mpg booster tune is designed for use with 87 octane
RE: mpg booster
Posted: Fri Oct 14, 2011 3:42 pm
by aviator14
Thanks for the help rjaro7
