2006 GTO No More TC Even When Turned On.....
Posted: Sat Aug 25, 2007 12:52 am
by collinms
I installed the predator tune on my 2006 GTO today and after I installed it I lost my traction control. I really want this back for rainy days. What can I do?
RE: 2006 GTO No More TC Even When Turned On.....
Posted: Sat Aug 25, 2007 8:48 pm
by collinms
no takers?
Posted: Mon Aug 27, 2007 1:23 pm
Please make sure the Predator is on the most recent revision, as this has been addressed in the 8r08 rev.
Re: RE: 2006 GTO No More TC Even When Turned On.....
Posted: Mon Aug 27, 2007 5:46 pm
by collinms
mikel wrote:Please make sure the Predator is on the most recent revision, as this has been addressed in the 8r08 rev.
Thats the revision I have... That was the first thing I did when I got the tuner was update it to latest.
RE: Re: RE: 2006 GTO No More TC Even When Turned On.....
Posted: Tue Oct 09, 2007 10:07 pm
by collinms
No progress I guess.
Posted: Sat Oct 27, 2007 2:24 am
by Carman319
I too have the traction control issue on my 05 GTO automatic after the latest update. I realy would like some help.
Re: RE: Re: RE: 2006 GTO No More TC Even When Turned On.....
Posted: Thu Nov 20, 2008 2:34 pm
by 06GTO6.0
collinms wrote:No progress I guess.
Nope, and there won't be any progress either. I have the same issue on my GTO. I would like for the TC to work, but they aren't going to fix it. It wasn't fixed in Revision 8r08 either, like was said. Here's another guy with an issue that probably won't be addressed either.
http://diablosport.com/index.php?name=P ... ic&t=10588
Seems like things are being swept under the rug, and focus is being put on newer products rather than supporting current and older ones.
RE: Re: RE: Re: RE: 2006 GTO No More TC Even When Turned On.
Posted: Thu Nov 20, 2008 3:05 pm
How is that being swept under the rug?
When you sweep stuff under a rug, you pretend it did not happen, and refuse to acknowledge that it did happen.
That is not the case here at all.
As to the statement about not supporting current tools, you should keep trac of the number of updates we have been releasing around here lately.
I still think the issue lies with the reduced TM making it easier to spin the tires, as we do not alter TC settings in the tunes, but if you are not sure, feel free to post up your current tune file and we'll check it out for you.
Re: RE: Re: RE: Re: RE: 2006 GTO No More TC Even When Turned
Posted: Thu Nov 20, 2008 4:21 pm
by 06GTO6.0
mikel wrote:How is that being swept under the rug?
No need to post up my current tune file.....just pull up the 93 Diablo Tune. That's the one I'm using right now. No other changes have been made to it. It's not an issue of reduced TM coming from the tune, its that the TC doesn't work at all!! This was apparently acknowledged as an issue, because you said an earlier revision fixed it. Well, it did not fix it, and from what I have seen posted here.....nothing has been done about it. That's what I meant by sweeping it under the rug. Thank You
Heck, if you wanted to make something disabled by default, it should have been CAGS!!!
Posted: Thu Nov 20, 2008 4:30 pm
Well, in order to make changes to a tune for you, we will need a copy of your tune from your car.
Posted: Thu Nov 20, 2008 6:18 pm
by Goatluver
Same with mine. Can spin the tires at will.
mikel wrote:I still think the issue lies with the reduced TM making it easier to spin the tires, as we do not alter TC settings in the tunes,
Same here because I do get the low traction on the DIC and from a higher mph roll the tires dont spin 'as much' with the TC turned off.
Posted: Thu Nov 20, 2008 9:58 pm
mikel wrote:Well, in order to make changes to a tune for you, we will need a copy of your tune from your car.
Mike, here's his tune file from outta his car.. 2006 GTO... using the canned Diablo Tune (93 octane)...
see if ya can make the traction control worky worky... :lol:
