Track results for 2010 Challenger R/T with STP
decker0861
Post by decker0861 »
I took my 2010 Challenger R/T with Super Track Pack to the drag slip a couple weeks ago. I've read on here that the 91 CAI tune is better for the set up I'm running (CAI and thermostat). The results were dramatically different between the 91 CAI, 93, and the 93 CAI tune. After data logging and finding a gas that didn't cause knock, I always run the 91 CAI tune but wanted to test it.
The 91 CAI tune ran 13.4, 93 ran 14.7 and the 93 CAI tune was right at 15. These times were ran at Richmond Dragway on Oct 7,2011 so you can do the DA calculations if needed.
I also turned the ESP off (posi track) but the faster 0-60MPH times were ran with the ESP on. Next time I go to the track I'll leave the ESP on.
Just wanted to throw this on here for a reference.
all_bran
RE: Track results for 2010 Challenger R/T with STP
Post by all_bran »
what did it run stock? Do you have any trap speeds or 60ft times?
You had a 1.6s discrepancy between different tunes? Sounds like something else went wrong... did it start raining for the other runs? LOL!
Sound like heat soak. How long did you wait between runs?
yeah, 1.6 seconds is on the driver, not the tune ;)
Safe to assume this is a manual trans?
all_bran
Post by all_bran »
I'm calling 60' times ranging from 1.9Xs to 2.4Xs :-)
yupper ;)
decker0861
Re: RE: Track results for 2010 Challenger R/T with STP
[quote="all_bran"]what did it run stock? Do you have any trap speeds or 60ft times?
You had a 1.6s discrepancy between different tunes? Sounds like something else went wrong... did it start raining for the other runs? LOL![/quote
I never ran the car stock. 1/8 mile 8.74 at 81; 1/4 mile 13.4 at 107 was my fastest time. The issues with the other runs will be addressed in future post.
decker0861
Mike_Levy wrote:Sound like heat soak. How long did you wait between runs?
I don't think heat soak was an issue as I drove an hour and a half just to get to the track. The temp was the same the whole night and the time between runs was about the same.
decker0861
mikel wrote:yeah, 1.6 seconds is on the driver, not the tune ;)
The car is automatic.
RE: Re: RE: Track results for 2010 Challenger R/T with STP
what were the 60' times?
there is so much more to a 1/4 mile pass than ET and MPH, especially when trying to diagnose changes.
oilslick
Re: RE: Re: RE: Track results for 2010 Challenger R/T with S
Post by oilslick »
mikel wrote:what were the 60' times?
Yeah, like spinning tires! Probably why you ran better times with the ESP on....those tires were spinning more with it off and you may have never noticed it....but the car did!
Once you go BLACK.....
