WOT - 06MonteSS Help
JohnBogovics
Post by JohnBogovics »
I have my LTFTs adjusted by -6% on injector slope. I have read 06MonteSS forms on adjusting WOT settings by 1/2 the slope. So would I adjust all my WOT PE RPM ranges (low, mid and high) by -3 (leaner), or do I follow the DSLOGREDUX program and adjust what it tells me in there which told me +6% low rpm, Med RPM was good and High rpm by -3%. I also noticed some TKSR after doing these adjustments from the DSLOGREDUX program in the low RPM range.
RE: WOT - 06MonteSS Help
I would go +3 in the lower range - those 4.8's are set lean in the low end... then leave the middle alone, and then go -3 in the upper range...
JohnBogovics
I will try this and let you know tonight
JohnBogovics
I decided to get a custom tune done and I had sent you the funds lew to do this. I sent you an email on a question
Thanks for the help though
Return to “Trinity GM Gas”
