1. = u7135
2. = v.9r27
3. = 2010 Dodge Challenger SRT8 6.1 hemi
After a data log and I review the log I cant access nor does the log indicate it has captured or show veheicle speeds above 127.5.
Also when I try to adjust the PID properties by right clicking the the Adjust Threshold option is grayed out.
What gives??
Tony j
Data Viewer not showing more than 127.5 mph vehicle speed
RE: Data Viewer not showing more than 127.5 mph vehicle spee
what version of DV?
Dabeast
Data Viewer version is V# 3.3.0.8 Build Mar 28 2011
Da Beast
Da Beast
This sounds like the max range for that PID. (I thought this sounded familiar. see http://diablosport.com/index.php?name=P ... highlight= )
See if there are other Speed PIDs in DV.
Dabeast
Thanks Jimb. Will check it out later today. I was using a Dash board sent by Arington maybe they didnt need to see Current Vehicle speed. Will post back my findings.
Dabeast
Dabeast
Dabeast
That leaves the Threashold issue. Are all the right click PID threasholds nonfunctional or are there some that the threashols can be adjusted? If some can be adjusted what are the most common ones that are adjusted?
Dabeast
Dabeast
Dabeast
I did find a 64x PID and did a track run and it showed 165.9 which was what I saw on the veh speedo. Thats one more prpblem solved thanks a buch jimb.
da beast
da beast
