U7140 - Cannot save original backup to PC
Posted: Fri Aug 31, 2007 1:30 am
by blike
For my predator for my 2005 mustang gt, i am trying to save my original backup to my computer so that i can upload some custom tunes onto my predator. The connection is all good, using port 115200 and COM port 4 as my driver is setup to, but everytime I click "Get Tune File from Predator" I get a backup failed message, the transfer never initiates because of this, and I'm unsure of why. Any suggestions? I'm using a serial to USB connector.
Posted: Fri Aug 31, 2007 11:14 am
by ski
The cause of the problem may be the serial-to-USB adapter. This same problem happened to others who used this adapter.
If you're not using a laptop, then you can install a serial port on your computer with a Serial PCI controller card.
Posted: Fri Aug 31, 2007 12:18 pm
What revision of which tool are you using?
Posted: Fri Aug 31, 2007 1:28 pm
by blike
I'm using the revision that the tool came with, so I assume a really old one. When I try to update to the newest one (r37), I don't understand what I'm supposed to do to "Power Cycle"
Posted: Fri Aug 31, 2007 2:02 pm
It want you to plug the unit in, (or unplug and then replug) that is the power cycle.
Posted: Sat Sep 01, 2007 10:32 am
by ski
Here are instructions for saving original backup to PC:
1. With the computer turned off, connect the Predator to the computer's COM port.
2. Turn on the computer, set the COM port's baud rate to 115,200.
3. Open DSDownloader.
4. You will get a message box saying 'Not Registered'. Click 'OK'.
5. Select the correct COM port in DSDownloader, and set its baud rate to 115,200.
6. Connect the Predator to its power adapter, and set its baud rate to 115,200.
7. Once the Predator is on the main screen, press ‘Get Tune File From Predator’ on DSDownloader.
8. A copy of the original backup file will automatically be extracted from the Predator.
9. Once the file has been uploaded, the DSDownloader will ask if you would like to save it in the .ori file directory. Choose 'No', and direct it to save the file to a location so that you can find it easily.
10. Your original backup file is now saved to your PC.
If the problem still happens, then see my previous post for a possible solution.
Posted: Mon Sep 03, 2007 1:34 am
by blike
Installed the latest revision onto my predator, and am still having the same problem, where my backup will get to 1% sent to my laptop, and then give me a "backup failed" message in the downloader. I'm thinking it shouldn't be the connector that's the problem because I was able to upload the update to my predator with no trouble at all.
Posted: Wed Sep 05, 2007 10:18 pm
by blike
Bump, any suggestions?
Posted: Thu Sep 06, 2007 10:21 am
Try opening up DSDL, then UNplug the USB cable from the PC, plug it back in and try again.
Posted: Sun Apr 04, 2010 3:38 pm
by tmg12345
I had the same problem. I clicked auto connect on the DSdownloader, that finally made it transfer.
