When the locator first appears, all I see is the south eastern portion of the US and a whole gaggle of devil heads out in the ocean. After I put my zip code in and input the encrypted code thing, what I see is a map view that is in the upper left portion of the display which only occupies 1/4 of that window. Also, although I select a GM dealer, I get nothing but FORD in the listing below. Anyone else having this
diablosport dealer locator
Is something going on with the dealer locator function here or is the problem just on my end?
2001 Camaro Z28 - GM LS6 heads and cam. SLP cold air LID & Loudmouth exhaust - n2o...
U7198
GM02 Predator
Software 2.13
Hardware 1.01
U7198
GM02 Predator
Software 2.13
Hardware 1.01
RE: diablosport dealer locator
Can anyone here tell me if the dealer locator feature is working correctly?
I really would like to get into contact with a CMR tuner for my modifications. What I'm seeing when I use the ds dealer locator is muddled. Thanks for any help.
U7198
GM02 Predator
Software 2.13
Hardware 1.01
U7198
GM02 Predator
Software 2.13
Hardware 1.01
Hi 01Z, I have found the same probem you dit but if you work within the top left portion of the window and dont over zoom in/out you can find what you are looking for.
By this I say zoom littile at a time and pan within the small window. Hope this helps.
Hi 99C5 and thanks for the reply. What you said does work but I'm still only getting FORD locations in the text below the map. It takes quite a while for the locator to work, the map works so slow with it that I just give up. Can anyone recommend a CMR tuner for my northeast Ohio location? The distributor that I bought my unit from does not do the tunes.
U7198
GM02 Predator
Software 2.13
Hardware 1.01
U7198
GM02 Predator
Software 2.13
Hardware 1.01
