05 duramax throwing code
Posted: Sat Nov 26, 2011 10:34 am
by 05dmax
I have the trinity programer and when I put it on my 05 Max the 100 horse tune.
When I get on it full throttle it throws a "p0700" is there any solution to this?
RE: 05 duramax throwing code
Posted: Sat Nov 26, 2011 10:35 am
by 05dmax
And also it puts it on like a limp mode
Re: 05 duramax throwing code
Posted: Thu Sep 27, 2012 9:46 pm
by yfzgoody
P0700 is a tranny code. Predator cant read the TCM codes. The P0700 is a code the TCM sends to the ECM to tell it to throw the code and check engine light. You limped your tranny. Have to take it to a shop or somewhere that can pull codes off the TCM to figure out what caused it to limp.
Posted: Thu Sep 27, 2012 9:48 pm
by yfzgoody
With the Allison it is also very wise to take it easy on your tranny for a couple hundred miles after you go "UP" on your tune. If you run on a tow tune and swap to a max hp you will probably limp it. The allison trans "relearns" the extra hp you are throwing to it. changing pressures and other things.
