compustar autostart predator not working
LYNNDRUM
Post by LYNNDRUM »
I had a compustar car starter installed now my predator will not work on my 2003 silverado 6.0. What do i do? HELP PLEASE
smackdownsrt
RE: compustar autostart predator not working
Post by smackdownsrt »
For starters, posting in the correction section. Here -> http://www.diablosport.com/index.php?na ... =index&c=9 And how it will not work would be helpful too.
...to be supported by Diablosport...
CANUCKPREDATOR
Post by CANUCKPREDATOR »
what do you mean your predator will not work? no power? no install?
if no power check you lighter fuse. OBD port is powered off light fuse.
that's an aftermarket remote starter... you need to disable/disconnect it before you can use your predator... the way they wired it up is interrupting the voltage/communications from the predator/obd port to your pcm....
this is why we tell people that ALL aftermarket electronics MUST be disabled/disconnected/pull the fuse for it before using the programmer...
installers for aftermarket electronics usually take the easy way out and tap into the obd port wires for constant power to the electronics they are installing, which screws up the programmer because of the power drain/communications blocking... this is why you need to disable/disconnect/remove/pull the fuse for any and all aftermarket electronics before trying to tune anything with the programmer...
this is not a predator/diablo problem.. this is an aftermarket electronics wiring problem...
Return to “Trinity GM Gas”
