Error Message: ECM: Error unlock for reflash (-1)
Posted: Wed Dec 14, 2011 4:31 am
by grayforge
I tried flashing my 2008 LMM with the 100hp tune using the U7186 programmer.
I initially let the programmer download a backup of my ECU, then started the 100HP flash. The tune seemed to be loading fine, but after a couple minutes it said there was an error loading the program into the truck's ECU.
It said that it would restore the original tune. However, it failed to restore the initial tune as well. Clicking the info button showed the message: "ECM: Error unlock for reflash (-1)".
So now I seem to be in an endless loop.
Luckily, I have HPTuners and had saved a backup of my stock tune to my laptop and was able to restore the ECU that way. But now the Predator is pretty much useless.
Any suggestions on how I can get the Predator back to normal and succeed in loading a tune?
Some specs on the tuner:
Model: 7186, Predator '06 - '08 GM
There's a tiny UPC code: 222061
I can't check what version of the software is installed in the predator since it won't get out of the infinite loop.
Russ
RE: Error Message: ECM: Error unlock for reflash (-1)
Posted: Wed Dec 14, 2011 10:40 am
give us a call with the tool powered up and we'll reset it for you.
Posted: Wed Dec 14, 2011 12:05 pm
by grayforge
Awesome, I'll bring it into work today. :-) You guys are amazingly responsive on this list. I have a Predator for my Dodge Magnum as well and got a quick update for a coolant temp fix for it here.
Any idea why a download to the ECU would fail? The ECU has been updated at least once by the dealer.
Russ
Posted: Wed Dec 14, 2011 12:10 pm
tough to say, possibly (and most likely) something int he truck caused it.
Posted: Wed Dec 14, 2011 4:50 pm
by grayforge
Called in... One of your efficient tech support reps helped me reset the tool. I'll try to update the tool and reflash the truck tonight.
Thanks!
Russ
Posted: Wed Dec 14, 2011 5:10 pm
Cool, let us know.
