using on other cars as obdII scanner
mperl93
Post by mperl93 »
I have a predator for my 04 Chevy corvette LS1. I wanted to know if the predator can be used as a scanner for other cars? I have a 97 Chevy Tahoe that has a check engine light on so I wanted to know if I could use it to read and clear the codes?
thanks,
Mike
RE: using on other cars as obdII scanner
The Predator will generally only work on supported applications, like on 99-up vehicles. For your tool, it will work on most GM vehicles 99-up that are not CAN equipped.
Return to “Predator Ford Gas”
