will mafia be enough
Posted: Sun Dec 18, 2011 5:12 pm
89 mustang gt. on3 70mm turbo. ford 05+ maf. 47# injectors. 255 walbro pump. i pegged my meter at 4100rpm with only 4#'s boost. part throttle. 1100kg/hr peg. but it was mad rich so i still gotta lean out the curve, which is gonna reduce my overall volt range. either way, i hear the 05+ fords go to 6.5 volts? i think with the MAFia i still might peg? unsure what the transfer function looks like past 5 volts but if i can only see a 20% increase in range im thinking i just need a vmp hpx meter or similar. ideas?
