Default Gauge Layouts Missing
Posted: Tue Dec 20, 2011 1:47 pm
by Badjustbad
My Diablo Trinity does not have any default guage layouts installed. When I select the "restore Default" option from the Monitoring menu it appears to try to resoter the defaults but there is no change (No gauge layouts are added). I know I can create my own, but if there are some existing gauge layouts I'd like to start there.
Is there some way to restore the default gauge layouts?
RE: Default Gauge Layouts Missing
Posted: Tue Dec 20, 2011 2:54 pm
by 06MonteSS
do it from the Logging menu/section... because changes made in the Logging menu/section are what appears in the Monitoring section...
Re: RE: Default Gauge Layouts Missing
Posted: Tue Dec 20, 2011 3:04 pm
by Badjustbad
06MonteSS wrote:do it from the Logging menu/section... because changes made in the Logging menu/section are what appears in the Monitoring section...
After selectined the Restore Default Gauge Layouts from the Logging menu, it still only shows the (2) gauge layouts I created.
Any other ideas?
RE: Re: RE: Default Gauge Layouts Missing
Posted: Tue Dec 20, 2011 3:06 pm
what vehicle is this?
What vehicle are you selecting?
Re: RE: Re: RE: Default Gauge Layouts Missing
Posted: Tue Dec 20, 2011 3:16 pm
by Badjustbad
mikel wrote:what vehicle is this?
2011 Silverado 1500 with the 6.2 and automatic trany.
RE: Re: RE: Re: RE: Default Gauge Layouts Missing
Posted: Tue Dec 20, 2011 4:11 pm
lemme check it out...
Posted: Tue Dec 20, 2011 4:26 pm
by Mike_Levy
I had this issue with the CTS-V also with one of the test CROMs. I don't know if it was the newer version that fixed it or if restoring the defaults while it was connected to the computer did.
Posted: Tue Dec 20, 2011 4:39 pm
by Badjustbad
I've trying to reset the gauge layouts while connected to the PC (No luck). Previously I had tried resetting the layouts while connected to the truck (Also no luck).
From reading other threads it appears the gauge layouts can be saved to your PC, so I assume there is also a way to load them in from the PC(?). If they can be loaded from the PC it should be a quick fix to send me a file containing the default gauge layouts so maybe I'm just misunderstanding the conversations - wouldn't be the first time.
