When I try to select a log file, only two show up and they were modified in 2009. I have looked for other files that I thought were saved and the ones that I thought were mine...it keeps telling me..."unhandled exception has occurred in your application...bla bla bla....
Argument "Length" must be greater or equal to zero
I'm not even sure if it's my log??
Could I please get some help??
I'm a computer dummy who saw a computer for the first time....only a little over a year ago!!
please post up the data log files that you're having the problem with and I'll take a look at them...
this is not a diablosport issue, since dslogredux is a 3rd-party program, created by myself and GrumpyAeroGuy - two diablosport tuner users like yourself
so if you post up the log files that you are having problems with, I'll take a look at them and will be able to tell you what you did wrong...
I get the same error... it's because your log file got saved wierd... if you look at the csv file, you'll see that it has blank rows between every data row... that's the problem...
what's your vehicle, what programmer are you using, what revision is it on???
also, post up the original .log file and I'll see if that happens when I save it as a .csv file...
I don't know how to post the original or what file I ran this thru?? I'm really not good with a computer. I'm trying to figure it out because I need to learn but this kind of thing sure does make a guy wanna throw in the towell!! What programs need to be in my computer for all of this to work right. I have windows 7, the dataviewer, dslogredux, and dsdownloader. And I have an 06 Monte, no mods, U7191 predator, v.9r03...... And have no clue how to work them. This sounds funny....even to me.
2014 Camaro SS/RS 1LE, CAI intake, Stainless Power LT headers, Bo White ported/polished TB, and a Badass tune from LEW!!!
post the .log file... use the dataviewer to get the data log out of the predator... then from the dataviewer, do a Save and save it as the .log file... then post up that .log file here, like you did before with the csv file...
Another question when I log the data.
In the list on my predator it shows
absolute throttle position
absolute throttle position B
commanded throttle position
which of those 3 choices should I be logging?? I have tried all at some point and still can't get logredux to work. I can get as far as the redux giving me a list of parameters but it won't analize the data for me??
air fuel ratio (Equivalence Ratio)
engine speed (RPM)
intake air temp
long term fuel trim bank 1
MAF Sensor Mass Airflow
MAF Sensor Frequency
spark advance
total knock spark retard
read the tutorial about how to do a data log correctly:
Just slow down and take your time. For the PIDS to work... Hence what you see on the scanner as to what you log just look at the handheld a when you do a log all. See what shows data for your vehicle. Then you can log what needs to be logged. I know for me i had like 2 colums for each PID and nothing would work right until i looked to see what acctually threw data out. Takes a little time. But well worth it....
See if you can get a new log... logging the parameters that 06MonteSS recommended. The first log you sent (.csv) has a almost double MAF reading at 1800 rpm as it should and the second (.log ) file is corrupt and can`t even be opened.
" Just Friggin Wicked"
Now with TCM support...
I have tried about 5 logs so far and get the same results. The second log is my original that he asked for!! Should I send my predator back and see if it's faulty or would it be in my new computer.....or maybe I dont have the right programs installed??? I'm lost as to my next move!!!
