2003 Dodge Ram 5.7 ABS-Parking Brake light Issue after tune
charlier
Post by charlier »
Received my Intune yesterday and installed the Diablo tune in my truck. 2003 Dodge Ram 2500 5.7. I now have the ABS light and parking brake light burning solid. Has anyone had this issue? Should I try reinstalling the factory settings? I'm new to this tuning stuff so any help would be greatly appreciated.....
Nolimitzr1
RE: 2003 Dodge Ram 5.7 ABS-Parking Brake light Issue after t
Post by Nolimitzr1 »
try going back and see. If it doesnt revert (lights stil on) you have a underlying issue which is just bad timing. I would then pull of the battery depress the brake pedal for a few minutes to reset the pcm.
If you still have the lights on or they return I would look into your parking brake switch (in my 05 impala if i was cruising and decided to play with e brake id get a abs light for a lil bit. could also be the abs sensor.
Also turn ignition to on 3 times and see if theres codes I maybe able to help you further.
charlier
Post by charlier »
Left for work this morning and after backing out of the driveway the lights cleared. Hopefully it was just a glitch and won't come back... Thanks for the reply....
rdss
Post by rdss »
Your inTune can check for trouble codes as well. Might be worth linking it up and checking for any.
2010 GMC Sierra 5.3
K&N Aircharger
felipealonso
Post by felipealonso »
The best solution is to bring it back to the former settings. OR Just an electronic bug around the truck as well.....
