Traiblazer SS idle issue with supplied tunes
I recently flashed my PCM with the supplied Diablo and 91 octane tunes. With either tune I am having a serious issue with the idle of the motor starting to lope on idle and progressively gets worse, almost to the point of stalling.
Was wondering if anyone else was having this same issue.
RE: Traiblazer SS idle issue with supplied tunes
can you post a copy of the backup and lasttune from your inTunes tune folder?
Will do. Soon as I can Thanks Mikemikel wrote:can you post a copy of the backup and lasttune from your inTunes tune folder?
yep, I know exactly what the issue is...
post up your tune files and I can fix it...
Thanks guys for being so attentive. I have the device at home today so as soon as I get there I will be sure to post those files.06MonteSS wrote:yep, I know exactly what the issue is...
Ok, here are the files.Satch606 wrote:Thanks guys for being so attentive. I have the device at home today so as soon as I get there I will be sure to post those files.06MonteSS wrote:yep, I know exactly what the issue is...
- PCM_ORI.grg
- (38.36 KiB) Downloaded 201 times
- PCM_LTW.grg
- (38.45 KiB) Downloaded 199 times
you know that you did not install a diablo tune, right? looks like you modified the stock tune and only changed the WOT fueling and timing.... you shouldn't be having any idle issue with that tune, since it's not a diablo tune, and the parameter setting that usually causes that, is not even changed in your tune at all, since it's basically just the stock tune...
if you want me to make the change to the diablo tune, then you'll need to install the diablo tune to your truck, and then get the new last tune written file and post it up here...
with that last tune written file you have posted now, you should not be having any idle issue, because it's just the stock tune basically...
Oh ok, my bad. Yes, This is the current tune that is in the truck.
So I shoud load up the Diablo tune and then post the same files as I did? That will give you the ones you need?
yes... you need to install whichever diablo tune you want to use in the truck... then after you install that tune to the truck, then get the last tune written file and post it up...
when you install the diablo tune to the truck, make sure you reset all parameters first, so that your current changes/adjustments to the timing and fueling do not get added on top of the diablo tune settings... you don't wanna do that haha...
I got ya. Will post it up soon. Thanks
Ok, Here is the original Diablo tune with the loping idle.
Apologies for it taking so long, been super busy lately.
- PCM_LTW.grg
- (37.49 KiB) Downloaded 198 times
here ya go man...
lemme know if you ever want a full custom tune from me to wake that thing up even more...
- satch_fixed.grg
- (34.92 KiB) Downloaded 198 times
