2011 EXT TCM-Shiftfirmness not working?
Post by 48548 »
I spoke to Lew after he fixed the hard lanching issue with WOT, thanks Lew. It seems like I have never been able to change the shift firmness in a way that I can actually feel the change. I have tried firm and now currently HARD options and doesn't seem to change anything. Here are the two crom files I have used and the last one is the one current on my trinity.
trinity_gm_can_gas-1r08h_update
trinity_gm_can_gas_1t08hl_update_786
Maybe there is a bug or I am smoking something or both :twisted:
RE: 2011 EXT TCM-Shiftfirmness not working?
after you installed that new crom revision update, you then reselected your vehicle/engine right?
go to options / show information and what does it show for the version/revision it's on?
48548
Post by 48548 »
I will check tonight. Yes I did reselect my vehicle. I am pretty sure when I did check it was the last file I posted above. The 1t08hl. But I will check again tonight to confirm it.
Avantgarde
Post by Avantgarde »
It never worked for me either, 48548!
48548
Post by 48548 »
I feel better, I thought it was something I did.
All on 1t08hl?
Post by 48548 »
Either of the two above from what I can tell.
48548
Post by 48548 »
Either two of the above I have seem to think it doesn't have any effect on the shift firmness. But the programer has the 1t08hl in it right now.
48548
Post by 48548 »
I just updated the tool yesterday, and still doesn't do anything no matter which option I pick, hard or firm or stock shifting. It always shifts the same.
please load the tunes then export a copy of the stock tune and last tune written and post them here.
Post by 48548 »
Here are the files....
The original are obvious.... the caddy_1 file I got from lew to fix the hard lurching from 1st to second and save my tranny!!!! and other are the last tunes written...
Last one written PCM_639835627567_mikekeyt_ecm_caddy_1_modified.grg
(4.25 KiB) Downloaded 223 times
Last one written TCM_256125258803_Trans_Hard_Shift_Tune.grg
(2.25 KiB) Downloaded 266 times
PCM_639835627567.grg
(67.9 KiB) Downloaded 226 times
TCM_256125258803.grg
(54.43 KiB) Downloaded 225 times
MikeKeyt_ECM_Caddy_1.grg
(56.86 KiB) Downloaded 220 times
48548
Post by 48548 »
Were these the files you were looking for?
yes, we'll check it out.
johan
Post by johan »
See how you like the attached trans tune here, let us know.
tcm_256125258803_001.grg
(41.5 KiB) Downloaded 233 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
48548
Post by 48548 »
I will try it. The question is why didn't any of the options change the shifting firmness? I like to be able to change them when I want to. I wasn't sure if there is something wrong with my tranny or TCM... I assume everyone else can change their tranny options and they work, so I figured it was an issue with my vehicle/tranny. Any special way to use the tune above, I have only used an engine tune, not a tranny tune. And if I think it shift to hard what options do I have? Also I wanted to leave on my TM on 100 percent as I have a heavy truck. I want firm shifts but don't want to risk the tranny life by removing TM.
Return to “Trinity GM Gas”
