Can I use Predator on different truck? Only (1) VIN allowed?
mooncruiser
Post by mooncruiser »
Does the programmer store the VIN? I have restored the original backup, got rid of the truck, and want to use it on a different truck, same yr, make and model.
thanks
Bob
ChrisDiabloSport
Re: Can I use Predator on different truck? Only (1) VIN allo
Post by ChrisDiabloSport »
mooncruiser wrote:Does the programmer store the VIN? I have restored the original backup, got rid of the truck, and want to use it on a different truck, same yr, make and model.
thanks
Bob
It depends on what kind of vehicle you have. If you have a Ford vehicle and your last tune written shows Original Backup then you will be able to use it on another vehicle.
If you have a GM vehicle, it depends on what Predator you have and what revision is on the Predator.
Thank You
Chris Johnson
1865 S.W. 4th Ave. Suite D2
Delray Beach Florida 33444
Phone: 561-908-0040
Fax: 561-908-0048
www.diablosport.com
mooncruiser
thanks
Bob
Chris-
I plugged in the programmer, did restore original backup, and now I want to use it on another truck. Both are Ford 6.0 diesels, 2005. It should be ready to go then, right?
Bob
ChrisDiabloSport
RE: Re: Can I use Predator on different truck? Only (1) VIN
Yup, you should be good to go.
Thank You
Chris Johnson
Phone: 561-908-0040
Fax: 561-908-0048
www.diablosport.com
Return to “Predator Ford Gas”
