Wil mafia work for my application
MAF.i.a Support
gsracer
Post by gsracer »
Its a little different than what you guys are used to but id like to see if this would work.
Its a nissan 240sx engine is a infinity q45 v8 with a vortech supercharger running a modified (live tunable) ecu with stock maf in a blow through application.
The stock maf is a hot wire maf that reads 0-5.114 volts and is pegged right now at 5.114 volts (max reading for the ecu) right before redline 6500 rpm (redline 7000). It is making 436 whp at 8 psi.
I need to extend this as i want to go up in boost to 10-12 psi and need some more range.
Will mafia work in this application.
Here is a picture of the setup
RE: Wil mafia work for my application
got a pic of the MAF connector?
Vas wants to know why you didn't just call him???
kmac1
Post by kmac1 »
More than likely you can make it work as long as its an analog signal. You will need pinouts to make sure its wired similar to a Ford. Check out the sticky in this section with the pinouts, it should help you.
What year is the engine and what ECM? What software are you using? I'm interested in the tuning aspect, cool project!
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: [email protected]
Return to “MAF.i.a”
