Data Viewer Question
jimmybuckets
Post by jimmybuckets »
Can the Data View be used to log 0-60 and other performance type parameters?
RE: Data Viewer Question
nope, no performance parameters (like a g-tech) are available...
jimmybuckets
Is the reason they can't do it because they don't have TCM support yet?
don't know / not sure....
No, it has nothing at all to do with TCM support.
The hardware in the Predator will not support that.
jsk06c6
Post by jsk06c6 »
Would be easy to figure out from the log. It records speed versus time after all. You could also calculate quarter mile times as a function of speed versus time as well.
Diablo could easily add this functionality to the DataView if they wanted.
Once I get the unit, suppose to arrive thursday, I'll check out the dataview a little more. If we can export into an excel spreadsheet it should be rather easy to make a macro to do the calculations. I'll let you know.
cool, more macros!!!! a guy after my own heart!!
jimmybuckets
I don't know how to do it...but I was thinking along the same lines...all the info is there to figure it out :)
jimmybuckets
Actually you can log vehicle speed and time is being logged already...is it that simple with the data viewer?
FastBlueSS
Post by FastBlueSS »
How much longer till TCM support?
jimmybuckets
Ha TCM...any whoo...I logged some 0-60 vs time loggs with the Data view...gives me a best run of 8.1 seconds...a little worse than what superchips flashpaq was telling me I was getting...is this a viable way of getting these times?
not really.. cuz it only takes data snapshots every so often... every certain amount of seconds... so more than likely you were faster than that, but by the time the next data-record cycle came around to record that time interval, you were already past it
jimmybuckets
I'm sure sample rate has something to do with it...my only question is that there were around 650 samples in that time span from 0-60...seems like it should be pretty close...just poking around here a little
jsk06c6
Post by jsk06c6 »
jimmybuckets wrote:I'm sure sample rate has something to do with it...my only question is that there were around 650 samples in that time span from 0-60...seems like it should be pretty close...just poking around here a little
It is. It's showing me at about 4.2 seconds 0-60. Thats about right for the conditions. Just hang jimmy, I'm working on the macros. But, I'm showing 6 thousands of a second between data writes in a log. Perhaps thats the problem the 7194's are having, we are grabbing data too fast. If they were to slow it down, the device isn't really going to able to give us the data fast enough to do these calculations. I'd rather it stay the way it is than increase the interval between data logs to increase the log time.
Best of both worlds would be to be able to select the data log interval.
Worse case, its a much better device as is, than what the others are. So I wont be upgrading it if it loses this functionality.
2006 Victory Red LS2 1LT M6, Halltech Stinger, 4" round B&B Bullets, B&B x-pipe, CCA Catch Can, Aluminum Throttle body spacer, Z51 sway bars
    sweet!! somebody else doing macros!!! WOOHOO!!!
