Page 1 of 2
how to datalog wideband AFRs
Posted: Sat Jan 21, 2012 11:33 am
by UnseenByYou
i've done a bit of searching around and googling but still couldnt locate the answer. i recently just hooked up the wires to datalog my wideband AFRs on my intune but i cant figure out what PID option is used to actually monitor the AFRs. if anyone can provide me with a answer or point me in the direction to find the answer id appreciate it. thank you
RE: how to datalog wideband AFRs
Posted: Sat Jan 21, 2012 6:05 pm
by rdss
I saw the option a few days ago while I was messing with it but can't remember were it's at. If someone hasn't helped you out by time I get home from work I will plug it back in look for you.
Posted: Sat Jan 21, 2012 6:55 pm
by UnseenByYou
sounds good, thanks
Posted: Sat Jan 21, 2012 10:22 pm
by rdss
Alright, not sure if this is the right way, but here it goes.
Select settings on the main page.
Select inTune Setup.
Select Analog Input Config.
Select Afd A New Parameter.
Thats as far as I can get you, it will ask to add name of new parameter. Good luck.
Posted: Sun Jan 22, 2012 9:08 am
by UnseenByYou
alright ill try it now, thanks
Posted: Sun Jan 22, 2012 9:25 am
by UnseenByYou
one last question and i swear im done lol. i got new parameter added but where is it at to select as a PID?
Posted: Sun Jan 22, 2012 1:02 pm
by rdss
You have to be plugged into the car, select the diagnostic tool (not sure of the name as my inTune is in the truck), select data log and it should ask you to turn on the car, then you will be able to dig through the data loggin options. Once you find you PID selections go to the bottom of that menu and it will have add PID and then find it in there. If you need specific instruction let me know and I will get the inTune powered up and guide you through it. Honestly I would just plug the unit into the car, turn the key to on with out starting it and just see what you have available to you, theres nothing wrong with learning the fine details of you tuner.
Posted: Sun Jan 22, 2012 2:41 pm
by UnseenByYou
yea thats what i did. i was scrolling thru all the options already. i found out how to get all the PIDs i needed when i first bought her but that wideband logging isnt showing. i will scroll thru again and see if maybe im just overlooking it or somethin
Posted: Sun Jan 22, 2012 4:27 pm
by rdss
Well I'm probably spent helping you out then. Hopefully the guys on here get you helped out.
Posted: Sun Jan 22, 2012 4:32 pm
by Ill_Born_SS
Got a laptop... see if it will log as a passthru in DataViewer.
Posted: Mon Jan 23, 2012 11:07 am
They will show up in DV, we have not yet added the ability to see them in the tool.
Re: RE: how to datalog wideband AFRs
Posted: Tue Jan 24, 2012 10:26 am
by starman
mikel wrote:They will show up in DV, we have not yet added the ability to see them in the tool.
I'm still holding my breath!!
RE: Re: RE: how to datalog wideband AFRs
Posted: Tue Jan 24, 2012 10:28 am
are you still not getting the analog inputs folder at the bottom of the PID list in DV?
Re: RE: Re: RE: how to datalog wideband AFRs
Posted: Tue Jan 24, 2012 2:21 pm
by starman
mikel wrote:are you still not getting the analog inputs folder at the bottom of the PID list in DV?
With DV I can, I waiting for the inTune functionality
RE: Re: RE: Re: RE: how to datalog wideband AFRs
Posted: Tue Jan 24, 2012 3:07 pm
OK, gotchya
