INTUNE HELP - 2007 SRT8 Jeep
GonzozSRT8
Hoping you could help me out. Just got my Intune. Updated via the web.
plugged it in my 2007 Jeep SRT8, asked to update for Jeep. Brought it
back in and did that on the PC. Plugged it back in the Jeep.
Message comes up "Determining vehicle info, please turn ignition to "on" pos'n.
Done. Then new message:
"Calibration update is ready to install. Install now?"
Pressing yes get me " Wiriting Tune: 1%"
then "an error occurred while installing calibration update"
"Continue"
clicking continue gets me:
"Itune is in recovery mode: continue?"
yes/no
Yes replays this scenario, no gets me :
"No ECU's found. Check ignition Key"
with a green checkmark after. which just keeps coming back
after I press it.
Hoping you can help.
Kevin
"Continue"
yes/no
after I press it.
Kevin
- JonDiablosport
RE: INTUNE HELP - 2007 SRT8 Jeep
Lets try to get that unit back to a brand new state will require a few codes etc so if please give us a call and we will see if we can get you through this or take note to fix the issue.
can you post or email the info.xml file here from the intune drive?
does the vehicle run currently.
GonzozSRT8
vehicle is running fine. check engine light is on though
here's the info.xml
<?xml version="1.0"?>
-<tool_info>
<main svn="3753" sw_rev="1r01d" full_version="InTune-1r01d 01/11/2012 11:05:00 AM"/>
<registration status="1" sn="CIAU070-1"/>
<restore bc="0" vin="1J8HR78307C579394" id="0"/>
<db pid="1r01a" tune="1r01b" mfr="GM"/>
<db pid="1r01a" tune="1r01a" mfr="DCX"/>
<db mfr="FORD"/> <system_db vin="1r01a" info="1r01a" dtc="1r01a"/>
<license tuned="0" avail="1"/>
</tool_info>
here's the info.xml
-<tool_info>
</tool_info>
OK, looking into it.
GonzozSRT8
Any chance this has to do with the fact it's a Canadian Jeep?
shouldn't, no.
GonzozSRT8
Any luck?
Yes, we have a fix, please give us a call with the tool powered up at your PC.
GonzozSRT8
ok, will call in about 50 minutes when my lunch starts
GonzozSRT8
Called, was on hold for 5 minutes. Assuming you were either busy or on lunch.
Will try again at around 2:45.
GonzozSRT8
Awesome support to get this sorted out. Sorry I didn't get the name of who helped yesterday.
Thanks again.
Kevin
Thanks again.
Kevin
Again, glad we could help, and thank you for being patient!
- Vas@Diablosport
You spoke with me on the phone. And as mike said, thanks for your patience with us while we sort this out.
No, i don't work here.
