data logging + wideband
Daytona1445
Post by Daytona1445 »
I think I already found my answers of "no" but I just wanted to confirm.
Using my Predator and Dataviewer there is no way to have the Dataview records input from my AEM wideband correct?
I know the AEM can stream the AFR directly to my laptop via a serial connection but it looks as if there is no way to have Dataviewer input and record it.
I would have to have a Trinity and use the 0-5v analog output on the gauge right?
thanks
gizmodo
RE: data logging + wideband
Post by gizmodo »
You need a Trinity or inTune.
Daytona1445
thanks for the reply. that is what i thought. I guess I will see if I can find other datalogging software that might be able to monitor the pids and take the serial input.
gizmodo
Post by gizmodo »
Look at an Innovate SSI-4. You'll use LogWorks with that.
Daytona1445
Thanks. I was reading about the Logworks plugin for the Predator yesterday and looking at the SSI-4.
Its not a bad option and only costs like $125.
I am thinking about one but I was also thinking that if I sold the Predator and took the money that the SSI-4 would cost I would only be off the cost of a new InTune by about $60-$65.
Since I am not going to be installing a cam till at least June I have some time to think about what I want to do. Until then I think the Predator is going back on shelf and I will reinstall my Superchips and custom trans tuning.
