2008 chrysler 300c 5.7 how do i change the fan settings
paulg10
Post by paulg10 »
intune part no. Cl B2ZA5. 2008 chrysler 300c 5.7 hemi. I just bought this diablosport intune and cant find anywere how to change the cooling fan settings. I put in a 180 DEG thermostat and want to change the fans to come on earlier at about low fan 185 deg and high fan at 195 deg. And also when to go off. can anyone help with this.
I found cooling fan . on one of the fan adjustments the heading reads COOOLING FANS AC OFF and then under it reads
high mph hs fan on
high mph ls fan on
high mph ms fan on
low mph hs fan on WHAT DO I DO WITH THIS?
JonDiablosport
RE: 2008 chrysler 300c 5.7 how do i change the fan settings
Post by JonDiablosport »
choose tune vehicle, write vehicle then choose the toon you want. When you see the message to modify the selected tune you hit the check mark then scroll to cooling fans, change from there. then press red back arrow until install tune apears. hit check to reinstall the tune.
Diablosport Tech support
p: 561-908-0040
F: 561-908-0048
paulg10
Post by paulg10 »
high mph hs fan on
high mph ls fan on
high mph ms fan on
change them all by -20*
