Vin locked yes or not
Posted: Thu Feb 16, 2012 8:08 pm
by niko
hi, you know the way to test if my predator is free or blocked without the car
predator U7145 for mustang gt 2007
RE: Vin locked yes or not
Posted: Thu Feb 16, 2012 8:24 pm
by Mike_Levy
Go to Options, Last Tune Written. If it says anything but Original Backup or Nothing To Show, its locked
Posted: Fri Feb 17, 2012 8:17 am
by niko
Thanks Mike, when I go on option exit only this: display serial number, show last tune written(inside Modify stock tune), custon tune, troubleshooting, serial baud,change transmission type, logo, oem select......nothing comes out more!!!
Posted: Fri Feb 17, 2012 10:43 am
its locked.
Posted: Fri Feb 17, 2012 4:57 pm
by niko
are you sure ?.....can not be used,I tried the predator only with power supply, I do not have the car now
Posted: Fri Feb 17, 2012 5:04 pm
yes, positive...
the last tune written says "modified stock tune" - that means someone used it to install a modified tune to their vehicle with it... so therefore, that predator is locked to the vehicle it was used on...
Posted: Fri Feb 17, 2012 5:24 pm
by niko
thanks ....I ask for reimbursement or payment of the unlock code to the seller, You need the predator in the company? what information you need to send the unlock code?
Posted: Fri Feb 17, 2012 5:35 pm
what revision is that predator on? power it up, and when it gets to the main menu, the revision number is shown at the top of the screen.. what is that number?
Posted: Fri Feb 17, 2012 6:38 pm
by niko
ok 06MonteSS : predator v.8r06
Posted: Fri Feb 17, 2012 8:53 pm
they can do it for you over the phone, don't have to send it anywhere...
first, you need to fill out the RMA form and select that you need an unlock.... then you will get a reply email monday or tuesday probably telling you to call them up...
fill out the RMA form....
https://www.diablosport.com/index.php?m ... ay&pid=108
Posted: Thu Mar 15, 2012 2:22 pm
by niko
Ok my predator is unlocked now after your code....but have a new problem: YOUR VEHICLE IS NOT IN OUR DATABASE. CONTACT YOUR DEALER FOR A FREE UPDATE. YOUR CAL_ID IS .........
USING PREDATOR u7145 FOR MY 2008 MUSTANG GT!! HELP ME PLEASE
Posted: Thu Mar 15, 2012 2:23 pm
you need to update the Predator to the latest revision.
Posted: Thu Mar 15, 2012 2:34 pm
by niko
predator v.8r06
Posted: Thu Mar 15, 2012 2:50 pm
by Mike_Levy
That version is from 2007. You need to update the tuner to 9r07.
Posted: Thu Mar 15, 2012 4:30 pm
by niko
done and all ok, thanks
