Problems retrieving log from U7191 using Dataviewer
Blown_red_97z
Post by Blown_red_97z »
I know the computer can communicate with the Predator because I just uploaded the most recent revision 8r09. But when I am using the DataViewer, the program finds the Predator for a second and then gives an error message saying "Failure retrieving tool info! Please reboot and consider updating your tool firmware". I am not sure what to do, any suggestions. It did this before as well with the 8r08 version. I am using the latest version of the DataViewer as well. I tried uninstalling the DataViewer, deleting all files associated with DataViewer, and still get the same error message.
johnc
RE: Problems retrieving log from U7191 using Dataviewer
Post by johnc »
A new version of the DataViewer will be posted tomorrow that may fix the issue. You are using a USB to Serial cable, correct? Which type of cable?
johnc <at> diablosport.com
Blown_red_97z
Yes USB to serial cable. Its just some random generic cables. The USB to serial I got from ebay and the serial cable came from radio chack I believe.
Blown_red_97z
also this is with windows XP, not Vista.
windows XP
media center edition
version 2002
SP2
johnc
Post by johnc »
Try this when you get the chance:
DataViewer 3.1.3.0
This release features a major rewrite of the communications layer to better support the various USB to Serial cables.
Blown_red_97z
still giving me the same error message. The software tries multiple times to connect with the predator but still give the error message.
Blown_red_97z
what cable can I buy that will not have any issues? Is there a cheap generic serial to USB cable available somewhere that will not have these problems?
johnc
Post by johnc »
Blown_red_97z
I have that exact USB to serial cable. Then again I really dont think its the cables causing this problem, especially since I can update the predator tool with the latest revisions. Any other suggestions?
johnc
Post by johnc »
If you are still using 3.1.3.0, try installing the latest (3.1.4.1). There have been major changes to the communications code during the last few revisions, so this latest update might make a big difference.
When DSDownloader connects, what COM port and baud rate does it say it is connecting on?
Blown_red_97z
OK I downloaded and installed the 3.1.4.1 and it still is not working. The DSDowloader never really connects, it searches the ports, finds the predator and instantly says "Failure retrieving tool info!" then it cycles around searching the ports again, and does the same thing. It connects for a milisecond to the tool, then gives the error message. According to my computer it is on COM9 at 115200. I dont get it, if I can connect and uploaded the newest revisions to the predator why cant I download the log from the tool.
johnc
Post by johnc »
I cannot reproduce your problem. I tried a 7191 tool with an 8r09, connecting through both a straight serial cable and a usb-to-serial cable, with DataViewer version 3.1.4.1.
Please email me your runtime.txt file from the DataViewer folder.
What version of DSDL were you successfully able to put a new CROM on the Predator with?
When you are putting a CROM on the Predator you are doing a large one-way transaction. When you are using the DataViewer there is a lot of back and forth. That is why the one is working and the other isn't.
johnc
Post by johnc »
Also, what version of Windows are you running? If you are using Vista, there are several things you might try under this thread: http://www.diablosport.com/index.php?na ... =9767#9767
Blown_red_97z
john I am emailing you the file right now. Also I was able to upload 8r08 and 8r09 to the predator with no problems. I am running windows XP
version 2002
SP2
sorry it takes a while to get back to you I am not online so often these days.
Blown_red_97z
funny you mentioned the runtime file I am getting this message after trying to start the dataviewer the second time.
Return to “DataViewer/DV2”
