Synthesized PIDs on the Trinity not showing on Dataviewer
RE: Synthesized PIDs on the Trinity not showing on Dataviewe
No, those synthesized PIDs are created by Trinity, it will always export the raw data the way it is now.
just during playback on the trinity?
ricks
Post by ricks »
Mike,
So, there is no Synthesized Boost PID on Dataviewer? I have Dataviewer 3.3.0.5. U7135.
I have a Kenne Bell 2.8 and am supposed to have the 8psi pulley. In measuring the diameter, it looks like I got the 7psi pulley. I want to measure boost using the Dataviewer logs to see what boost I'm actually getting. Exactly what do I have to calculate to equate boost? Will that be accurate or "close?"
Thanks,
Rick
2009 Challenger SRT
Kenne Bell 2.8LC Supercharger
monitor MAP and Baro, and subtract Baro from MAP pressure to get boost.
ricks
Post by ricks »
I'm still not getting it. My Baro is 29.44. When in boost my MAP hits 151.6.
There are a few different Baro choices. Which one? Is there only one MAP choice?
Rick
2009 Challenger SRT
jimb
Post by jimb »
You need to have both BARO and MAP display the same units of measure. (e.g. kPa or inHg). The BARO reading of 29.44 sounds like inches of mercury (inHg).
Return to “DataViewer/DV2”
