NO serial flash found u7135
mysrt-8
Post by mysrt-8 »
I tried to update my predator from r-12 to r-30 and the hand held said no serial flash found. Now my computer will not talk to my hand held. How do I get back to r-12. Help :(
RE: NO serial flash found u7135
Restart the computer. Plug the cable into the tuner first, and power it up. THEN plug it into the computer. Open DSDownloader, make sure auto connect is selected and let it find the tuner. Then you should be able to reinstall 9r12.
No, you have to use Legacy connect once the tool goes to application missing or corrupt, dsdl will not find it.
OP, there are instructions on the dsdl main screen that show you how to use legacy connect to reload the crom.
Where did he say that it went to application missing or corrupt? He just said it went to no serial flash found.
if dsdl wont find it, it needs legacy either way ;)
