DS Log Redux
AZ_Rider
DS Log Redux
Post by AZ_Rider »
So i'm trying to use DS Log Redux for my inTune, but it seems like it can't read the csv file that the inTune logged. Am I missing a step?
2010 Silverado Crewcab LS 4.8:
Airaid CAI
RC 2" Level Kit
Duraliner Bed Liner
Dynomax VT Cat Back Exhaust
Diablosport InTune
RC 3.5" Lift Kit is next!!
rdss
RE: DS Log Redux
Post by rdss »
You have to hit Verify Log Parameters first. It will have two pop ups that you ok and then you click Analyze Log File and it will do it's thing. I select 1800-2200 rpm range as well because I set my cruise control at 1850-1900 rpm for cruise logging. Make sure your equivalency ratio is selected to log as well or the software will not analyze your file.
2010 GMC Sierra 5.3
K&N Aircharger
AZ_Rider
RE: DS Log Redux
Post by AZ_Rider »
I'll have to go back and look at the log options to make sure i'm logging correctly!
Airaid CAI
RC 2" Level Kit
Duraliner Bed Liner
Diablosport InTune
rdss
RE: DS Log Redux
Post by rdss »
If you haven't added the equivalency ratio PID then the software wont work. If you haven done anything other than hit log that is probably your problem. When you're logging make sure you are on a flat striaght road and keep the RPM between 1800-2000. I have found that 5th gear in my truck (5.3 w/ 3.42 rear) at 58 mph holds just over 1800 and 75 mph in 6th holds it at just above 1800 as well. See if you're logging it and go from there.
2010 GMC Sierra 5.3
K&N Aircharger
RE: DS Log Redux
you have to copy the log file from your intune to your harddrive on your pc... then open that .log file with diablosports DataViewer program...
from there, go to File - Export to CSV and save the log file as a .csv file to your PC's harddrive...
then dslogredux will be able to open that .csv file...
