Installed predator on my 05 ram and now lights are on
Posted: Wed Mar 07, 2012 7:55 pm
by 05ram2500
u1737 part #
Put this programmer on today and the abs and park brake lights are on now, whats the prob? any help will be much appreciated.
RE: Installed predator on my 05 ram and now lights are on
Posted: Wed Mar 07, 2012 8:26 pm
by Mike_Levy
You turned off Traction control.
Posted: Wed Mar 07, 2012 8:32 pm
by 05ram2500
The truck is a 2005 ram 2500 4x4, didnt know the truck had traction control. What do I need to do to fix the problem.
Posted: Wed Mar 07, 2012 9:04 pm
by Mike_Levy
What Revision are you running? It will say on the top when you plug in the unit. It'll be 8rxx or 9rxx. If its an 8r version you need to put your stock backup back on the truck and update the tool.
In the Modify Tune section, there should be a selection for either Traction Control or Dyno Mode. If its Traction Control, make sure its ON, if its Dyno Mode, make sure its OFF.
If that doesn't do it then I have no idea what the problem is and you'll have to wait until the Tech guys come in tomorrow.
Posted: Wed Mar 07, 2012 9:50 pm
by 05ram2500
it is a 9r13
Posted: Thu Mar 08, 2012 9:17 am
by LeHemi
If it is traction control it should reset when the key is cycled i think.
Posted: Thu Mar 08, 2012 1:18 pm
did you adjust tire size?
Posted: Sun Mar 25, 2012 11:52 am
by bighemitex
sounds like you wiped out your abs info and a dealer reflash is probably in your future.
Re: RE: Installed predator on my 05 ram and now lights are o
Posted: Sun Mar 25, 2012 11:53 am
by bighemitex
Mike_Levy wrote:What Revision are you running? It will say on the top when you plug in the unit. It'll be 8rxx or 9rxx. If its an 8r version you need to put your stock backup back on the truck and update the tool.
i'm pretty sure the rams don't have traction control options or the dyno mode. it sounds like this guy might have set his tire size while installing a tune and wiped out his ABS info.
