u7194..part throttle timing
I only see parameters for WOT. I have a customer with an 07 Z06 that has part throttle ping. I called and after sitting on hold for 25 mins the tech had no clue. Is there an update for this model? There are very few parameters to adjust. The manual is wrong and not specific to this model. I sold it 2 just weeks ago. I'm hoping to get an answer because I've sold 4 in the last week and fear more calls.
Is the vehicle throwing any codes for KR? You can monitor total timing, max fast spark retard, or total knock retard to see if the PCM is pulling timing.
Does this car have any other mods, as we tested on stock vehicles and that is what the tunes are designed around. If the car has been modded further, it may require a custom tune.
If you do not have a CMR dealer in your area, let us know and we will help with a tune via email.
I didn't see a place to moniter total knock retard. No mods. No codes. I left a message for you to call me at 9 a.m. I was told you were off today.mikel wrote:Is the vehicle throwing any codes for KR? You can monitor total timing, max fast spark retard, or total knock retard to see if the PCM is pulling timing.
That is strange, if there are no codes there is usually no knock. These knock sensors are very sensitive.
Are you hearing valvetrain noises? Monitor total timing and see if it is dropping at any point.
I am out of the office today, I'll give you a call tomorrow.
Have you asked your customer what brand of fuel he is using and maybe have him try a different brand, quality does vary between brands of fuel quite drastically.
You can also try to add some more fuel via the Predator.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
