"corrupted" graphics?
Posted: Fri Mar 09, 2012 6:24 pm
by sota
only with that specific gauge type, and only in that position though.
RE: "corrupted" graphics?
Posted: Fri Mar 09, 2012 6:29 pm
is it overlapping another gauge?
Posted: Fri Mar 09, 2012 6:36 pm
by sota
negative.
if you look carefully you can see, that the corruption "behind" the gauge is actually one of the menus.
i'll go see if I can figure out which menu exactly.
also, the corrupted image only shows up when I attempt to log, and only AFTER the logging starts. the screen prior where you press 'record' does not have that image corruption. I have no idea if it also does it during monitoring, as my unit FAILS totally to ever work in monitoring only mode.
Posted: Fri Mar 09, 2012 7:28 pm
by sota
think i'll uninstall the tune tonight, reload the 1r08 CROM, load the 1r08c and 2011 image updates on top of that, and see what happens.
Posted: Fri Mar 09, 2012 11:58 pm
by sota
some notes.
corruption occuring on
medium digital gauge
medium radial gauge
corruption not occuring on
small radial gauge
new (blank) gauge layout
medium digital, AFX, Upper Left only, no corruption
medium digital, AFX, Upper Right only, corruption
medium digital, AMB TEMP, Upper Right and Lower Right only, corruption
medium wiper, AMB TEMP, Upper Right, no corruption, but gauge is bigger? set range and corruption is now visible since it changes the 'style' of the gauge. if it doesn't overlap the x/stop/edit buttons, no corruption!
so apparently, the 3 'buttons' on the touch screen are important, and when a gauge is a little too close it causes the graphics problem I photo'ed.
fyi... fixing that in an update might be nice. having 2 Medium gauges side-by-side and 2 bar graphs below them as 2 other gauges would be a really nice combo I think. or having an option for each page to enable/disable the visibility of those touch-screen buttons would be nice, since the two physical buttons do two of the tasks already.
Posted: Sat Mar 10, 2012 12:50 am
try not loading the image update, not sure why it is still there, but the images are part of 1r08.
Posted: Sat Mar 10, 2012 4:17 pm
by sota
is there a way to uninstall it? or do I need to wipe the tune and force the 1r08 CROM on to the unit and let it find all the other updates it wants?
Posted: Thu Mar 29, 2012 9:37 am
load 1r08, then let it auto update to all of the latest incrementals.
