5th gear in Autostick
Posted: Tue Oct 09, 2007 8:55 pm
by Nemo
Hi, I just got my Predator yesterday and updated and installed it. I have a 2006 chrysler 300c 5.7L. I intalled the autositck upshift tune and when I switch to autostick from D at a stop , it reads 4 gear. Does predator have 5th gear ? and will it change it so that when I shift to autostick from D at a stop it changes to 1st gear? I ask this cause I just switched from superchip which allowed that. Or did I not installed the right autostick tune? thanks
Re: 5th gear in Autostick
Posted: Tue Oct 16, 2007 12:20 pm
by jumpoo
Nemo wrote:Hi, I just got my Predator yesterday and updated and installed it. I have a 2006 chrysler 300c 5.7L. I intalled the autositck upshift tune and when I switch to autostick from D at a stop , it reads 4 gear. Does predator have 5th gear ? and will it change it so that when I shift to autostick from D at a stop it changes to 1st gear? I ask this cause I just switched from superchip which allowed that. Or did I not installed the right autostick tune? thanks
I dont get the 5 either?
RE: Re: 5th gear in Autostick
Posted: Tue Oct 16, 2007 1:55 pm
by Boggus
I just loaded mine in my 06 charger and do have all 5 gears. I have Auto Up Disabled.
Posted: Thu Oct 18, 2007 2:26 am
by Nemo
yeah, found out you have to disable the autostick then you get the 5th gear.
Posted: Thu Oct 18, 2007 8:41 pm
by RobAGD
UNtil the really start digging into the TCM, you are not going to see the same results from the tuning as you did with the SC tuner.
The 5, the Auto Scrol down are all in the TCM from my understanding.
-R
Posted: Thu Oct 25, 2007 9:52 pm
by damageinc
just got mine today.....Ive got 5th showing,mines 07 300c
Posted: Thu Oct 25, 2007 11:48 pm
by OsuThunder
Mine was fine, then today I updated to the new update. its great but my 5th gear no longer showes up either.
I cant shift to it, it just goes back to drive. ALSO I used to be able to, while driving, push the stick right and it would go to the higher gear for that speed..... now it does nothing.
other than that its great so far.
oh yeah, mid 07 RT with R&T
Posted: Thu Nov 01, 2007 4:51 pm
by OsuThunder
anyone else? any comments from diablo? just checking.
Posted: Thu Nov 01, 2007 9:21 pm
by damageinc
maybe disable mds?then 5 will show...maybe.....????
Posted: Fri Nov 02, 2007 7:54 pm
by Jected
Issue here and others in Australia. It is like the car now has 2 D's.
The regular D (drive) and the one in Autostick. Definitely not right and needs to be addressed.
Only thing I can fault on the unit.
Posted: Mon Nov 05, 2007 5:17 am
by Jected
Bump to the top
Posted: Sat Nov 10, 2007 2:20 am
by 10SecS4
Mike @ Diablosport started a thread over on the lxforums specifically aimed at Predator shifting/autostick issues. You guys might want to post over on that thread if you haven't already:
http://www.lxforums.com/board/showthrea ... ost1195212
Hope this helps.
