Is the U7195 not around anymore?
kylehamilton79
Post by kylehamilton79 »
I have a 2003 Chevy Silverado, 5.3, and the same U7195 I've had programmed on the truck since 2007. I was going to re-install the performance tune tonight and adjust everything like before and see if it would perform better but after doing that I'm having hell getting the idle adjusted back to normal.
Before the idle was just fine and I never had to adjust it, but the first time I fired up the truck it was idling about 350 RPM so I had to take 10 minutes and go back in and adjust it, without any luck. I only know how much I'm adjusting it, not where the idle will actually be.
Just wondering if my programmer is obsolete now and that's why it isn't working right. I haven't even used it since I put the performance tune on it. I emailed Johan since he helped me a long time ago, but I'll take help from anyone that can get my truck back the way it was earlier today.
RE: Is the U7195 not around anymore?
The u7195 was replaced by the U7193 a few years ago, you can send it in for the $99 hardware upgrade to convert it to a U7193 and it will come back with logging ability, and be internet updateable, etc.
