Please Connect Intune First!!!
CHoquette
Post by CHoquette »
Application Number: 1r01g
Dodge Ram 1500 2009
When I connect my Intune to my computer and I click on INtune.exe I get the following message Please Connect An Intune First. I called tech support and He sent me an update via e-mail and the Intune got updated but still the same message still pop ups. Anyone could help me?
RE: Please Connect Intune First!!!
is it telling you the driver is not installed?
right click on the intune.exe and select run as administrator, see if that helps.
autox
Post by autox »
Same thing here
Car on the dyno
3 hours later i still cannot use intune.
Re: RE: Please Connect Intune First!!!
autox wrote:Same thing here
Car on the dyno
is your issue with the driver?
your email gave NO information to help you, Id dint even know what tool you were using...
This is a simple fix, which has been posted here time and again, right click the intune.exe, select run as administrator, and all set.
CHoquette
RE: Re: RE: Please Connect Intune First!!!
Post by CHoquette »
I had that issue and still with the administrator thingy didnt work at all! Sometimes there is more then one bug with the same result like please connect intune first. I had to ship it back and get a new one!
Ram 1500 2009 Laramie, Ds Intune, jba shorties, moes Tb, L&M custom Trans, Moes Catch can, E-Fan, Custom double exhaust 2.5 + x-pipes, Ripp SC
autox
Post by autox »
Again.. car on dyno... same intune.. .run as administrator doesn't work... its requesting a cal update and i can't update.
Please help.
