Application Missing or Corrupt
Posted: Thu Oct 11, 2007 8:41 am
Precise steps to fix a Predator with an "Application Missing or Corrupt" message:
- Download and install the latest DS Downloader from HERE
- Download the latest CROM file for your predator from HERE after selecting your Predator part.
- Connect the Predator to the PC but do NOT power it on yet.
- Run DSDownloader on your PC.
- From the Options menu, choose Auto Detect to un-check it (Auto Detect cannot work with a corrupt Predator).
- Click on the "Express Tune Mode" tab at the bottom.
- Select the appropriate COM port and baud rate settings on the toolbar (the defaults are probably correct, but these may need tweaking).
- Click on the "Send CROM file to Predator" button.
- Select the CROM file that you downloaded earlier.
- Now power up the Predator.
- After a couple of minutes your Predator should reboot and no longer be corrupt.
