Hello ,
I have a U7151 tuner and would like to know if I can use the Airaid tune for an Airaid Jr. cai on my 06 F150 .
The Airaid Jr. is different than the regular Airaid cai so I was hesitant to download the tune .
Thanks ,
Randy
Airaid Jr. tune on F150
RE: Airaid Jr. tune on F150
it uses the tube, right?
does the MAf housing change?
If so, you will likely need to use the tune...
It uses a tube that replaces the stock intake tube .
The maf does not change .
It uses a drop in high flow replacement filter using the stock intake setup .
What do you think ?
What do you think ?
if MAF does not change, should be no need to change the tune, but you'll know for sure if you get lean codes
So should I just use the 87 octane tune or try the Airaid 87 octane tune ?
There is no tune on it now .
no need for the airaid tunes if MAF is stock. use the standard octane tunes.
Thanks for your help Mikel !
