Dodge Ram 09 hemi - failed to read pcm Original Backup
hi!
ive seen some other people are having the same problem... im from europe - and i bought 2 intunes for 2 dodges.. on the first it does not work because of "failed to read pcm Original Backup".
In the attachment you can find the info.xml... maybe someone can help me... i payd tax in austria --> so the 2 tunes cost over 1000 Dollar. -> its not so funny...
anyone who can help me ?
thank you - rene
thank you - rene
- info.xml
- (435 Bytes) Downloaded 146 times
RE: Dodge Ram 09 hemi - failed to read pcm Original Backup
first thing I would do is update this tool, it is on a very old version now.
hi mikel!
i did it before i used it in the ram... the picture of the update utility shows "this intune is up do date with Diablo´s current releases.
No calibrations need updating !
what to do now ??
thank you - rene
what to do now ??
thank you - rene
that info.xml says it is on 1r01d, we are up to 1r01h, open the updater, and click update/check now.
RE: ram...
ok, it is up to date now.
RE: ram...
i already tested it - same problem again!!
RE: ram...
we're checking it out still.
RE: ram...
thank you - is it a problem thal will be checked during the next days or should i send the intunes back ??
RE: ram...
sorry, but because i dont want to miss the last day to return the 2 intunes its really important for me what i can do now ??
RE: ram...
today i tried it with the second ram (i have 2 intunes) - same problem... it is a 2010... i cant believe it.......
RE: ram...
Having the same issue with an '09. Any update or additional info would be great.
RE: ram...
we are looking into this.
RE: ram...
do you think you will find the problem or should i send the 2 intunes back ??
