No adjustable parameters
hemimag1
Post by hemimag1 »
Mr. Dialbo,
Hooked up your product to my 2008 Dodge Magnum last week.
It informed me that a tune was avaliable for my ride, and installed something...
There were no multiable tunes, nor any questions as to what type of tune I may have wanted to install, ie., 89, 91 or 93 octane...
Did not ask about a CAI, or aftermarket exhaust...
After it installed, there were no options on the adjustable prameters icon, it
was not even lit up...
I purchased your product right after it was released to the public, and waited till there were a few updates avaliable, as I knew the bugs would be running rampant in such a new product.
The car is running fine, but can't really feel much difference.
So, after all this, can you tell me what this tune actually did, and why exactly
there are no adjustable parameters avaliable to me..
The real reason I purchased the InTune, was the stated ability to adjust for throtthe response, tire size & the ability to turn off that awful MDS.
Please advise at your earliest.
lar
RE: No adjustable parameters
try this...
select the tune, then when it asks if you want to modify that tune, choose the green check mark, and then it will give you a lis t of all the things you can change, like throttle response and MDS disable.
Tire size adjustment is in the quick adjust menu.
hemimag1
Post by hemimag1 »
OK, I'll give it a go & let you know...
thanks!!
dhuckins
Post by dhuckins »
Question. Can I change certain things under the modify stock tune while keeping a canned tune such as 87. I just want to change tire size on f150 2006, to 35s.
no, changing is tuning, and you can only tune one at a time ;)
hemimag1
Post by hemimag1 »
Mr. Diablo,
Your instructions were dead on, all is well...
thanks so much!!! :D
dhuckins
Post by dhuckins »
Hmmm....I didn't get asked to modify, so I could change tire size. Let me try it again :)
