cmdp
wburners
cmdp
Post by wburners »
Question. anyone out there installed cmdp plates and when car is cold it stumbles/cuts back alittle at lower rpms until its warmed up? When its warm it runs like a bat out of hell. Also it was tuned for them. Also have comp stage 2 nsr cams too. Just curious. If you step on the gas it seems to be fine.
wburners
RE: cmdp
Post by wburners »
just wanted to add also it just seems more "cold natured" than before.
RE: cmdp
sounds like it just needs some more tuning...but you also lose a bit of low end torque from the plates, and the cams likely moved the powerband up in the rpm range as well.
Return to “Predator Ford Gas”
