2007 monte carlo ss
Posted: Fri Apr 13, 2012 1:55 pm
by slankadank1
i just received my trinity programmer and and i think its awesome!only problem im having is my car has a cold air induction kit and wants to cut out or die under somewhat of a load>im assuming i need a tune for the cai for it to run properly.my question is can i just get the proper tune downloaded at any dealer or tuner nearest me?is it gonna cost me more money?thanx
RE: 2007 monte carlo ss
Posted: Fri Apr 13, 2012 2:15 pm
a custom tune will cost a few bucks, but there is agreat write up here that will get you started for free
http://www.diablosport.com/index.php?na ... opic&t=917
Posted: Fri Apr 13, 2012 2:41 pm
by Mike_Levy
He shouldn't need one for a stupid intake though. Theres a problem someplace else. Probably a vacuum leak or air leak someplace, or a dirty fuel filter since its happening under load.
Posted: Fri Apr 13, 2012 3:34 pm
by slankadank1
right,i was thinking maybe its running way lean since the car ran just fine until i put the cai on it which was prior to the trinity hookup.guess i'll double check all my connections.thanx
Posted: Fri Apr 13, 2012 4:38 pm
yeah, something's not right...
so after you installed the CAI it's been running like that?? check all clamps/bolts, make sure everything is TIGHT... make sure you didn't disconnect anything and forget to reconnect it after you were done, etc... you've got a physical/mechanical issue with the car somewhere...
