srt8 gc esp disable?
Posted: Fri Oct 12, 2007 9:38 pm
by yamaha1
Hey fellas, I tried to disable the esp and just like one guy already said it dosent sound right. I drove 100 ft and it sounded like the all wheel drive was screwd up. Is the GC made to work with the esp feature or is it just for 2 wheel drive srt vehicles?
RE: srt8 gc esp disable?
Posted: Sun Oct 14, 2007 1:45 pm
by BJB
Yamaha1, I agree. I won't disable the ESP again via Diablo. On my 2007 GC srt8 I have a completely separate unit that I use. It has 3 rocker switches, ESP on/off, FWD-2WD, Fan on / off. As you could imagine, ESP off in 2wd mode it will roast the rear tires for quite some distance. Then again, when you are dealing with almost $900.00 of rubber you don't do that often. Let me know if you want the info on the kit I installed.
BJB
Posted: Sun Oct 14, 2007 4:50 pm
by hemi8tr
i think that the problem is that all the other companies esp disables leave the abs on. the diablo turns off the abs and the steering has inputs from the abs sytem. you can try to turn the wheels all the way right and then back to the left and see if that helps.
Posted: Sun Oct 14, 2007 8:56 pm
by BJB
The other mod I have installed on my vehicle... Or the non Diablo way of turning off ESP also turns off ABS as well.
When I experimented with the Diablo way of turning off ESP I noticed a strange warning that said "Service 4wd system" I'm sure the Diablo people will get it worked out.
